SEI Replacement Drives & Ratios
mrdjflores
first off, sorry if this has been asked before, some of this can be confusing..
have a 1973 Merc 888 (ford 302 v8) and outdrive
from what i understand...the outdrive is the MC-1 w/ 1.50 ratio
is the SEI se106 a direct replacement drive? also, lists as a 1.47 ratio..
from their site:
SE106 (replaces MerCruiser's
R/MR/Alpha One I/O)
doesn't particularly mention the MC-1 drive
opinions?
Don S
Re: SEI Replacement Drives & Ratios
You couldn't tell the difference between a 1.47 and a 1.50. It's all done with a calculator.
havasuboatman
Ensign
You aren't using a calculator, are you? :)
Dons right. run the 1.47 you won't notice a difference.
mrdjflores
i was more concerned that SEi doesn't list a drive for the MC-1
Ayuh,... The Alpha 1 is a direct , Plug & Play for the Model 1s...
betayv
you need a sei 106 1.47 like the others sayyy go for it.
mrdjflores
tanks everyone for reassuring me
elkhunter338
Master Chief Petty Officer
I think you need the sei 106, talk to sei and they will help you out. I put a sei 106 on my boat this spring. Merc 140hp, 1971 outdrive. These sei outdrives are noisy at first before you get the gears broke in.
I put 100 hrs on mine this summer with no problems. Make sure and change the oil at 8-10 hrs like they recommend you will have some metal in it.
I changed mine at 8 hrs and at 100hrs. I had numerous hours to trolling and running. My drive is pretty quite now after I got about 40 hrs on it.
I had no problems with sei.
mrdjflores
okay, another quickie....
will the Alpha I Gen II bolt up directly also to my pre-alpha configuration??
Nope,... The Gen.IIs are a different breed....
