Serial Number Locations
bstig60
I have a 1988 Mercury Classic Fifty 45HP engine. I have been unable to locate the serial number. Is it located in multiple places? If so, where?
Chinewalker
Should be one of two places. There is (was?) a tag on the motor's swivel bracket with the serial on it. These tags can be faded out, washed off, or otherwise removed over the last 30-odd years.
The second place would be stamped on the motor block itself. I am pretty sure the 45/50 got it somewhere on the upper portion, near the flywheel. May be hidden by cowlings, brackets, etc.
bstig60
The tab on the swivel bracket is long gone. I took a close look around and below the flywheel and couldn't see any sign of a stamped serial number on the block. Would it be on the carb side of the block or around the cylinder head?
GA_Boater
No guarantee on this, but it may be stamped where the red highlight is below.
bstig60
The only number I found are on the head and that is 1017-8359. Nothing aft of the flywheel on the top of the block or on the area indicated in red. I found a number stamped on the block water jacket plug. It is B-368471.... Is this it? If so, what a place to put it where it is on a part that is replaceable.
Fun Times
Yes that's the serial number but when looking up a parts diagram, put a 0 in front of the B...0B368471. That number comes up as model number 1045412BD which makes it a 1988 MERCURY 45 ELPTO
http://www.mercruiserparts.com/selec...?doc_nbr=16403
