Re: set-up of power trim and tilt unit
thanks for the info. I should have made myself a little clearer...my PT&T unit came as a compete unit..it was simply unbolted from the motor...transom bracket, hydraulic units etc. all assembled. I was looking for tips and general knowledge from y'all before i started. I did however, notice my cylinders have an allen head set screw and a straight slotted screw, which one is the bleed screw, I have a feeling it's the straight slotted one but, " thinking isn't knowing" so i ask you. Also my wiring harness has the three pin conf. there is two other leads coming off of it, a blue and blue/white in one connector and a purple w/white stripe in another conn. are these for the limit switch. And the 12V power supply to the pump must hook to the insulated block on the pump, does this all sound right?
