Re: shift interrupt
Chris
That u on YouTube...Chrisa660?
:facepalm: Yes, that's me...
Glastron cutty said:
If so nice video on adjusting the shift cable.
Thanks.
I see my problem...the roller isn't sitting in the middle of that valley and my switch button is being depressed. How do I get that back in the middle?
Find out why it's off centre. Disconnect the lower shift cable and see if it returns. 2 options.
1. If does return. Find out why the lower cable is holding it. (Probably stiff and needs replacing).
2. It doesn't return to centre. Remove the lever arm (the one with the valley that trips the switch), clean & grease the pivot, check the return spring (bit of wire looped around it)...
When the roller is centred in the valley, the switch needs to be set up so it closes when the gap between the roller and the arm is 1/8"...
Chris.......
