Shift Interrupter Switch DIY Repair...
vandentr
In case your original style shift interrupter switch goes bad, I came up with a $3.00 repair that could potentially get you back on the water while debating whether or not you want to spend $160 on a new style plate/switch assembly and waiting for it to arrive.
For me the failure of the switch wound up being caused by carbon buildup on the contacts in the switch after years of use. Fully depressing the plunger by hand with the engine running had no effect, so I knew something was screwed up in the switch.
The switch is riveted together, and since you can't buy a replacement I figured I had nothing to lose by carefully drilling out the rivets and seeing what was up.
I only drilled enough of the crimped side of the rivets to loosen them up, then carefully tapped what was left of them out with the butt end of a drill bit. After that work, the cover came off without issue:
As you can see there's not much to these things, but there are a couple of things to take note of.
1) There are two separate springs on the white plastic plunger that press against opposite sides of the plastic divider, make sure that these wind up in the same configuration when you put it back together.
2) Use a fine-grit sandpaper or other abrasive to clean off the affected contacts.
Securing the cover back on was the trick, good luck finding those specific rivets locally.
My work-around was to go to the hardware store and grab one 8-32 thread-cutting machine screw and two 8-32 pan-head stainless steel screws. I drilled out the two small screw holes in the cover (upper two holes in pic) to allow the 8-32's to pass through and then used the thread-cutting screw to "tap" the same two smaller holes in the main switch body.
I then used the new SS 8-32's to secure the cover and filed off the remnants of the rivets and re-inserted them into their respective (larger) holes where the retaining screws pass through to attach the unit to the shift plate.
So now, when you look at the switch, there are two additional screws holding the cover on, but they do not interfere with the function of the switch.
After re-mounting the switch to the plate and adjusting the trigger arm a little bit, the switch is back to working like it should!
you can buy replacments. that is just a roller lever limit switch.
Alumarine
Thanks for that.
It looks like a good quick way to get going again.
johnkom
I've done that with starter relays. In fact if I remember correctly the relay on my trim pump has been disassembled, cleaned and reassembled.
Thanks for sharing.
Question for Scott: I've never found a micro switch with the right dimensions to replace it. Are you sure you can find one? If so, link?
JK
dingbat
There is nothing special about the switch.
It’s a common snap switch. No problem finding something that would work if not the exact switch
Digikey or Mouser could get them for you if they don’t have them in stock.
achris
More fish than mountain goat
.... Use a fine-grit sandpaper or other abrasive to clean off the affected contacts....
DO NOT use sandpaper! Use newspaper.
Switch contacts are coated with a very fine layer of either silver or gold. Using sandpaper removes that layer and exposes the more vulnerable copper base. In the presence of high voltage, that copper will pit very quickly and you'll be back in the same situation again, no continuity through the switch...
Newspaper will clean the contacts without removing the coating.
Chris....
vandentr
Chris....
This is not a high voltage/current situation, but your point still stands, especially if you intend to keep the old switch in place for an extended period of time.
My plan is to get through the next moth or so and then upgrade to the new plate/switch assembly.
achris
It is high voltage. The voltage that switch is grounding is around 400v....
