daveydoodle
- Joined
- Jun 15, 2011
- 160
Gents, Have a 97 Evinrude that I dropped the gear case to replace seals. Putting gear case back on motor and noticed the holes that the shift rod connects to(Behind starter) did not line up perfectly.Is a 3/8 head & the screw has a smooth area where it rides on the assy,about 1inch long.Able to screw it on w/ a little coaxing,then second guessed myself if it shouldve been a perfect fit(as it came off last fall). Am I OK w/this fit or try to adjust up & down or side to side. Poss. manipulate the gear shift while doing so. I am 99.9% certain the rod is still in same position where it screws into gear box.
