Boats-A-lots
Thread starter- Joined
- Jul 22, 2012
- 366
Three yrs ago I had my lower cable replaced in my 89 4.3 cobra. When I picked the boat up from the shop they said "shifts like new". I didn't use the boat for about 4 months, and when I did it wasn't any better in shifting. The shop where I had it replaced went out of biz, so I couldn't take it back there.
Fast forward 3 yrs, the shifting became harder and harder til a few weeks ago no reverse, and wouldn't come out of forward. This time I was going to fix it myself. The cable broke when I unhooked it and gave it a tug. Uh huh.. humm. I took off the out drive and what was left of the cable would move with ease.
It took a rubber hammer and wood block (tapping lighting but firm) to get the shift rod to move up or down. I WD-40 it and it moved easier. After it sitting for a couple of hours it would freeze up again. (waiting for my cable to get here). For 2 days, this has been going on. It would be so hard to push up or down after sitting a few hours. Last night I put lower gear lube on the shaft and let it pool up at the base where it goes into the seal. This morning, the shift rod moved with ease.
I think maybe I better replace the seal on it as I don't want water getting past the seal. (so far that hasn't happened).
Here's my question! Can the shift rod and seal housing be remove (after removing the anode) or do I have to take the lower unit apart?
Also, I wonder how many others this happens to thinking the cable is binding, or out of adjustment. Since the cable moves so freely with the out drive off, there was no other explanation why it shifted so hard. I read these is an upgrade on the shifter detent, that is suppose to help in shifting hard.
