Hello all, I have an 89 OMC I/O. When I bought the boat I had over $1,000 worth of service done to the outdrive because the I had problem putting it into nuetral. The mechanic found water in the outdrive so he repalced two bellows, Gimbal bearing, and shift cable. I took it out to the lake the first week, and the shifting was fine, however I did take on some water in the bilge. I took the boat out for the second time this weekend, and it is difficult putting the gear in neutral again!!!!<br />Where do I check to see if there's water in my bellow? I am concern that water is getting in the bellow again and damaging my new shift cable. Please help.. thanks.
