Shifting
EARLS BOAT
I Have An 88 Bass Tracker With A 70hp Evinrude It Wont Go Into Reverse And Some Times Will But Wont Stay. Would You Think Clutch Dog Or Shift Cable Linkage Out Of Whack? ALSO WHAT IS A GOOD MANUAL? I WOULD LIKE TO FIND A JOHNSON/EVINRUDE MANUAL BUT I CANT FIND ONE FOR 88 YEAR MODELS. I HAD A SELOC BUT I DID NOT FIND IT TO BE VERY GOOD BESIDES IT ONLY WENT TO 40HP.
CATransplant
Re: Shifting
First step is to disconnect the shift cable and see if it shifts manually into reverse and stays there. If it does, then you probably need to adjust the cable.
Have you recently had the lower unit off on that outboard?
EARLS BOAT
Re: Shifting
I Will Get Back To You With That Model #
shes a keeper
Re: Shifting
sounds like a shift cable adjustment i agree wth disconnecting the cables but before you do unsnap the cable supports and simply tightened or loosen (usually ) tightened the slack will slide in gear if not then what cat said is the way to go
kenmyfam
Re: Shifting
Check the simpler stuff first as suggested. Much better to find you have to adjust the cables than realising that after you tear the motor apart.
tashasdaddy
Re: Shifting
had the lower unit been of just before it started doing this????
EARLS BOAT
Re: Shifting
no it just happened all of a sudden. i'm praying its just a cable adjustment. it is ok to pray about your boat jesus liked fishermen!!! i have it at a local boat shop at the moment.
