skunkedskippy
Thread starter- Joined
- Apr 30, 2017
- 132
Hello all. I picked up a used swim step for my 1977 Skipjack (it came off another skipjack). When I bolt the brackets to the swimstep, they don't all lay flush against my transom (about 2 or 3 mm gap). I tried switching the brackets to different positions, but still not all flush. I don't want to fill/redrill holes in the swimstep, so I figured I could shim the gaps with a plastic material, between the brackets and transom.
I was able to source PTFE and PVC shim stock that I could cut and stack to fit. Links below.
Please let me know if this is a good/bad idea, or what other options I have. Thanks!!
www.mcmaster.com
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
![IMG_1550[1].JPG IMG_1550[1].JPG](https://forums.iboats.com/data/attachments/378/378301-764fe55b01463847dfc5e42e2aae1a86.jpg)
![IMG_1551[1].JPG IMG_1551[1].JPG](https://forums.iboats.com/data/attachments/378/378302-d38e8be7b924372f294286417cb9158c.jpg)
