Shim material for swim step bracket
skunkedskippy
Hello all. I picked up a used swim step for my 1977 Skipjack (it came off another skipjack). When I bolt the brackets to the swimstep, they don't all lay flush against my transom (about 2 or 3 mm gap). I tried switching the brackets to different positions, but still not all flush. I don't want to fill/redrill holes in the swimstep, so I figured I could shim the gaps with a plastic material, between the brackets and transom.
I was able to source PTFE and PVC shim stock that I could cut and stack to fit. Links below.
Please let me know if this is a good/bad idea, or what other options I have. Thanks!!
Gee, flat shims? Aluminum plate, big washers, a piece of a walmart plastic cutting board, lots of stuff could be used.
Black UHMW, HDPE or delrin
Black because they are UV resistant
PVC isn't UV resistant
909
Made some shims recently out of composite decking
garbageguy
+1 on that. Lots of materials will work on the short term - UV resistance will help in the longer term. In 35 yr experience with large quantities of these materials - some exposed to UV, some not, you can really see it visibly and in lab test data.
As noted above, some HDPE has a black additive package that helps that plastic- material be more UV resistant.
Augoose
As said, lots of materials you can use. Be sure that you cut your shims in such a way that there is no gap between the bracket and the transom so there's no opportunity for movement or rocking.
Gee, I would think the Walmart plastic cutting board ($5) would last forever. The question is the thickness, IMO.
skunkedskippy
Thanks all. I think I have some scrap starboard laying around. I guess I could sand it down to thickness.
Starboard is just an expensive HDPE just like cutting board.
However cutting boards are not UV stable
skunkedskippy
Today I hung the swimstep up to my transom. Below are pics of the transom/brackets gaps, while pushing the unit by hand.
Do I even need to shim this?
skunkedskippy
Or, maybe I could shim all 4 brackets, tighten all bolts down the same amount, and the brackets that started with a gap will "squish" a little less than the ones that started flush?
I would slather the back side with a layer of UV4000, bolt it in place
dingbat
I would start by flattening out the mounting bracket.
Put an 1/8” thick nylon washer under each mounting hole and bolt it up.
skunkedskippy
Thanks everyone, but this is the best suggestion - I tend to overthink things and make them more complicated than I need to.
Already had 5200, so I marked, drilled, checked fit, slathered, and bolted up.
