bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
haveing a few issues all at once, but hope to peel away and isolate for questions.
yesterday the starter wasnt turning fast enough to make spark, in the morning at 0 degrees. but later after charging the battery and it warming up to 28 degrees it did start.
now today the motor was sounding like it was missing now and then. While motoring i slowed and put the shift lever in nuetral and the motor sounded like it was going to die..but before i could move it back into gear...thus giving it more gas as well...it did die!! for a second, but once i pushed forward..it started again..
it did this three seperate times...
yesterday i did pull the yellow/black lead off the iginition switch, in an attempt to isolate a no spark issue...but i put it fully back on!!!
just thought Id mention that.
my motor eventually died, and I could not restart...dont know if it was the weakend starter...or this newer issue...
had to run the kicker to come home!!
two questions...what could cause the motor to die going to nuetral, but make it come back to life by giving it throttle( after it turns off!!)
also, what part of the starter needs to be replaced-rebuilt, so that it spins faster, to make a more powerful spark???( my mechanic gave me a test to check this...all plugs in, the spark wont jump my spark tester..but all the plugs out and the spark jumps 7/16ths")
I dont want to spend $280 on a starter just yet
thanks
bob
thanks
bob
