size of vacume lines.....?????????????
gordwa
Does anyone know what the size is of all the tiny little hoses that come off the carbs ,and attach to the block check valves and also to the primer on a 1990 ...90 hp and where I can buy it in bulk.Thanks
boobie
Re: size of vacume lines.....?????????????
Try your BRP dealer. He should have it in bulk.
Will Bark
If you don't have a BRP dealer close by then a NAPA store should have it.
gordwa
I will try that...Thankssssss
boobie
If you go to NAPA make sure they're alcohol resistant.
oldboat1
They MAY be the size of the small clear gas lines used in some chainsaws, weedwhackers, and other small engines. Check the above sources, and also hardware stores (local ACE hardware carries a lot of that stuff).
emdsapmgr
The recirculation hoses on that engine are 1/16", ethanol resistant, sold by Bombardier dealers by the foot under part number 772568.
