Philster
Thread starter- Joined
- Sep 15, 2009
- 3,344
There is some heated discussion going around in other places I won't mention.
Nonetheless, the non-disputed facts go like this:
Outboard-equipped boat running on plane. Debris or other sudden panic-inducing issue causes operator to slam throttle to neutral and then reverse almost immediately, or from forward to reverse. There are documented cases of this causing the engine or engines to hydrolock. In the cases I've read, they are Yamaha o/b engines. Yamaha has even warrantied some engines that have hydrolocked (engines had bent con rods and other damage).
The disputed facts:
Water entered the engine via the exhaust vs. water entered the engine via the intake.
There are two camps that align themselves with one explanation or the other. "There is no way water can come up via the exhaust; not just by slamming it into reverse; it came in via the intake!" vs. "There is no way it can enter the intake; these must be cases of it coming in via the exhaust!"
There is another delusional camp that believes the engine ran in reverse cycle (internals rotating opposite of norm). Since these are four-stroke o/b engines, I prefer to discard this possibility, but would entertain the theory for a moment, if we were talking about 2-strokers, as they can run in reverse (we 2-stroke engine builders call that 'dieseling').
I wanted to get iboaters' takes on this issue. Because owners are relaying the information, there isn't much extra detail (for example, if it happened to me, I'd want to know more about where the water was actually found. Surely, if the engine ingested water via the air intake, I'd expect evidence of that and lack of that evidence might point me to the exhaust).
Please opine. I lean towards water ingestion at the intake, but I also know there are always chances for water reversion at the exhaust.
The disputed facts:
