Smart tab no fit- other suggestions?
Philster
Re: Smart tab no fit- other suggestions?
I agree with using something (wedges) to create offsets to get the parallel to the actual transom.
Stingrays that porpoise need tabs.
Tabman
iboats.com Partner
Tom,
In your second picture, your tabs are mounted on a flat transom (straight across from corner to corner). My transom is not straight (or flat). Below is a very crude drawing of what I've been trying to explain all along.
The Trim tabs in the picture are actually parallelogram in shape that we build for a boat manufacture who made boats with "offset" transoms. The angle happened to match the boat. If you know the angle of the offset I would be delighted to see if they would work. Or as Philster mentioned you could shim them.
We make some very short actuators that could help in this type of installation as well as some very low profile hinge plates that should fit.
If you are interested let me know and we can discuss this further.
Tom
UncleWillie
...The outer section of the hull runs back on an angle, so I can not use that area either...
Why Not!
They do not have to be mounted straight back.
The inward transom angle will tend to cancel the effect of the deadrise angle.
If you have the newer version with the tracking ribs on the bottom, a few minutes with a power sander could remove them.
markheck1
Somebody has to still make the spring loaded tabs like I have on my boat. Wanna Trade? LOL
drtydeed
Why Not!
Naticus said no.
rschap1
rschap1,
No, I have not tried other props. That could get expensive unless I can find a loaner. I just purchased this boat used with 25 hrs on it, so I have not had much seat time in it (just about 3-4 hours). I hear so many negative views on hydrofoils so I'm a bit leary of that idea for this boat.
There is a prop shop in my town that does just that. I stop in, tell 'em what boat, motor, and desired use I am fitting for and they recommend and loan me some props. I had bought 2 used props that were in need of their repair services. I dropped those off and left with 3 props from their loaner service. For the type and style of boat you have, I really think having the proper prop would fix you up. The same prop shop that I mention does prop customizing too. To an extent, they can alter the cup of each blade, and custom tailor for what you are after. High dollar high performance rigs call it "labbing" the props. It can make a BIG difference. If I were smarter in this area I could make some recommendations, but all I know is I walk in, tell the guy behind the counter my symptoms, I get prop back and all better:) Maybe there is someone here with that kind of knowledge to help you out. I have added planer wings to the outdrive of some of my earlier boats and found it is really not the best solution. Easy and cheap but not best. The volvo straight down drag plates look just like brakes as stated. Sure can't help fuel consumption.
