Smart Tabs.
Catchem
Re: Smart Tabs.
OH YEAH,we love our jet skiers over here too.(not)That's the main reason we all have to have an operators license over here because of the inconsiderate way they operate their crafts.BTW <br />Nautijohn where can I get those smart tabs in my neck of the woods.I have a 20' Tempest with a 4.3 L OMC Cobra.
bubbakat
Re: Smart Tabs.
I ordered me a set on the 16th and received them friday and installed them . Went to the water and I am now going to get me another set for my other boat and my brother was there and he is ordering him a set.<br />Thanks John for one heck of a no nonsense product that actually works.
Bayrider
Re: Smart Tabs.
Hi bubbakat. Did the 25 degree setting work for you or did you have to adjust.
bubbakat
Re: Smart Tabs.
I adjusted it back to about 20 % and it will lift and corner real well.
LubeDude
Re: Smart Tabs.
As of yet that I can remember, No Negative reports on the Smart Tabs. I allmost had one, but with the right adjustments all is well, really well!
Jdeagro
iboats.com Partner
Re: Smart Tabs.
Hi Bubbakat, Bayrider, and LubeDude;<br /><br />I am delighted that you are all getting the results you hoped for. I was down in Virginia, and the Little Creek Naval Base for a conference and testing. Lot's of interesting watercraft, and that was only what they allowed us to see. Anyway I was unable to check this site before now.<br /><br />Catchem;<br /><br />Please call Dour Wright at 705-722-3022. He is our sales representative in Canada and will be able to direct you to the best dealer. If you have any problems, let me know at 800-233-0194.
Catchem
Re: Smart Tabs.
Nautijohn,Lo and behold,a couple of days after talking to you We had a new dealer open up down the street from and he carries your product.Showed them to me on his boat and says he couldn't believe the differance in performance.Gave me one of your installation manuals to read as well.Under $300 bucks Can installed.will definately be getting a set and will let you know how I make out.Thanks for your help.
Rudderman
Re: Smart Tabs.
I have the 2004 Union Chandlery Catalogue from Cork, Ireland and the list prices for the smart tabs are:<br /><br />8-18hp €129.77<br />20-25hp €129.77 <br />30-40hp €169.71<br />40-80hp €169.71<br />60-90hp €229.63<br />100-175hp €229.63<br /><br />I''ll be buying the 8-18hp set myself and I will let you know how they work out.
Jdeagro
iboats.com Partner
Re: Smart Tabs.
Catchem;<br /><br />Make sur eyou get the manual if the dealer installs them, and let us know how they work out.
Catchem
Re: Smart Tabs.
Definately will let you know NautiJohn,and thanks again.
Scuda11
Re: Smart Tabs.
Ok, SmartTab fans and enthusiasts, question:<br /><br />I have a 20ft Proline C/C, with a 1983 200hp Johnson. Weight is 1,400, I usually have 2 adults, 2 kids.<br /><br />Would these help me out? I am looking for a little more hole speed, and some top end never hurts anybody, but would give up a little for hole speed.<br /><br />Just looking for some recommendations, thanks guys!
Jdeagro
iboats.com Partner
Re: Smart Tabs.
I'm-a-learning;<br /><br />You are expecting too little! Smart Tabs do not help with a "HOLE SHOT" because they do not allow you to get into a hole. No Hole - No Hole shot! Just acceleration! Flat and Level!<br /><br />Properly adjusted, you should gain about 2 to 4 MPH.<br />If you expect no low speed wander (5mph. nowake zone), lower planing speed, improved ride and handling, no porpoising, and better fuel economy then that is a lot, however thats what you get. Satifaction Guaranteed! No Bull!
Jdeagro
iboats.com Partner
Re: Smart Tabs.
I'm <br /><br />By they way we are now selling to the Navy and the Coast Guard for the boat 24 feet a under.<br /><br />The Nav Sea group has them under extensive testing for their combatant craft - remote control.
Scuda11
Re: Smart Tabs.
hoo-rah. Maybe I will go browsing thru the store room here! I am now a CG Civilian Search and Rescue Specialist in Boston.<br /><br />You know, just in case they need a set "tested" ha ha<br /><br />Thanks.
Das Boot
Re: Smart Tabs.
Hi John<br /><br />I have a smart tab question, just about to buy a used Zodiac MK 2 Futura hull (speed tubes) 13'9" overall length rated; for 20 to 50 hp<br /><br />I think i'll put a used 25 or 30 hp on her, tiller steering and no power tilt or trim, which concerns me as i may have to mess around with motor position (tilt) settings.<br /><br />Will the smart tabs allow me to choose a permanent optimum motor trim setting and leave it to the smart tabs to do the rest<br /><br />thanks
Jdeagro
iboats.com Partner
Re: Smart Tabs.
Yes! <br /><br />Use the ST980-30! Your motor trim will likely be in the second or third hole from the transom.
Das Boot
Re: Smart Tabs.
Hi John;<br /><br />Thanks for that on the Zodiac.......and now another question please.<br /><br />I was telling my friend about "smart tabs" he has an 1989 mint Bayliner Ciera Sunbridge 24.5<br /><br />The boat has hydraulic trim tabs but he "fiddles" with them constantly, once trimmed from side to side if he moves around the boat (fer instance get a beer from the cooler :) the trim goes out of "whack" Would smart tabs help eliminate his problem? I mean remove the previously mentioned ones and goes with yours.............<br /><br />regards;
Jdeagro
iboats.com Partner
Re: Smart Tabs.
Although Smart Tabs would probably compensate for this movement adequately, I would recommend that he get more comfortable with his current system. It takes practice.
rnsi
Re: Smart Tabs.
Hello John-<br />Can you recommend a SmartTab model for me? I have a '87 Bass Tracker 1710 fiberglass pro bass style boat with a 150 OB. Or should I be looking at the Monster Tabs? I'm looking for a smooth, level ride throughout the rpm range, and will be towing skiers occasionally. Right now, I can either troll, or go full throttle, nothing in between.<br />Thanks!
