SmartCraft Controls
sasto
I have these controls on a Boston Whaler. There is supposed to be an adjustment on the tension under the cover. Anybody know how to access the adjustment screws. I really don't want to take a hammer and chisel to her.:facepalm:
attachment.php
Don S
Re: SmartCraft Controls
Remove the side covers, there are adjustment screws under them.
oops!
lol.....those are really nice controls bud......wow.
I think you already know all this stuff im about to post.....and your question is brand specific......but here goes any how
It looks like the port side cover comes off.
If you pull the cap off the pivot point of the handle and un screw the bolt in there.....and undo the screw on the cover....you might be able to get at the base mounts.
If not.....I regularly go into the console from another point....ie..ill take out the gauge panel and stick my hand thru the hole to un do the mounting bolts on the plate of the shift console.
The other thing...is I don't understand tighten tension???....the cables don't really work like that....the adjustment is for the distance between the mounting point and the cable thru pin. a good cable wont have tension in the movement.
this is a side mount control.........different ......but the same....lol
the cable end
this is a pic of the barrel that screws to the shaft of the cable.....the barel fits in to the end of the shift housing....this is the only adjustment.
this is the clip that screws into the base of the mount
and the clip that holds the cable stationary into the mount to the cable end can freely move.
the cover that holds the whole shabang in place
the assembled unit
oops!
lol don......we were posting at the same time......
and yes......it does look brand specific
Don S
There is one other minor difference, there are no cables, only electronics and wires.
DTS = Digital throttle and shift.
sasto
WOW. Thanks alot guys. I don't know how many hrs I spent in the www. Going to walk to her now and check it out!
oops!
DIGITAL.....?????
what fun is there in that? :D
actually......im dying to get my eyes/hands on the new Axius system.......I want to disect that puppy !
Don S
DIGITAL.....?????
01000100 01101001 01100111 01101001 01110100 01100001 01101100 00100000 01101001 01110011 00100000 01110011 01101111 00100000 01101101 01110101 01100011 01101000 00100000 01100101 01100001 01110011 01101001 01100101 01110010 00100000 01110100 01101111 00100000 01110111 01101111 01110010 01101011 00100000 01110111 01101001 01110100 01101000 00101110
oops!
how do i get spit coffee off my puter screen and under my keyboard?
roscoe
And requires only a 3 key keyboard.
hungupthespikes
"Digital is so much easier to work with."
Not fair Don, that took me back to old school.
huts
sasto
DIGITAL.....?????
The fun came when I was coming in the inlet and also docking her. The controls are way to easy. Just a slight touch and they move. I should say fun to watch me....:eek:
I checked them out and they are just like the diagram Don posted. I will adjust them later today and post a photo or two for anyone interested.
