Re: solar panels
Rosser:
Sorry, please don't be offended, but that is question is like asking how many feet does it take to make a horsepower. (Well not quite that bad, at least volts and amps are slightly related.)
Amps is the current flow, which is directly related to the number of electrons flowing past a point in a second. Volts is the electrical "pressure" that makes those electrons move. For an analogy, consider a hose with water flowing thru it. The amount of water flowing thru the hose is similar to Amps (both of which might be described as current). The water pressure making that water flow is similar to volts.
And finally, as a free-be, the term resistance is analogous to the degree to which the hose allows water to flow. Long hose has high "resistance", narrow hose also has comparatively high resistance. Similarly a long wire will have high resistance as will a wire which is too small in diameter.
TerryMSU
