spartanpele
- Joined
- Jul 5, 2005
- 183
This past weekend I took my 1987-85hp Force to the lake for a test run. I came back with mixed results. <br /><br />It ran fine for a while, although it seemed to lack any top end speed as I could only get my boat (17 ft Bayliner cuddy) up to 30mph. During the slower speeds of no-wake zones, the engine was dogging. I figured that was because the exhaust tube seal wasn't installed and it was killing itself idling slow in the dirty water/exhaust. (The exhaust tube seal is one of my next projects.)<br /><br />Eventually I decided to head back to shore as it was starting to sound rough and idling poor. By the time we got to the dock, the engine had died. I loaded it up on the trailer and took a look at the plugs, fuel filter and other misc hoses. Everthing seemed fine, so I put her back in the water, and she failed to start. Having had enough of the inconsistent motor, I headed for home.<br /><br />Once home I hooked up the muffs and tried to see if she would start. She not only wouldn't start, but, wouldn't kick over either. After several troubling shooting items, I noticed a gas recirculation hose that wasn't connected, and, the ignition key was still in the on position!<br /><br />I turned off the key and connected the vacuum hose. After checking the battery charge, I tried to turn over the motor. The motor wouldn't turn over and the dash panel wouldn't light up when turning the key. <br /><br />Q: Is it possible to burn out a solenoid if the key is left in the start position, battery attached, while trailering and towing the boat all the way home? If I "jump" the solenoid I can get the starter to kick in, but otherwise, nothing, so I'm betting the solenoid is bad.<br /><br />My last question is about the spark plugs. The spark plugs I'm using are NGKs (BUHX). I suspect they're faulty and want to replace them. My manual states I should use Champion UL18V. I'm having a hard time finding those locally. <br /><br />Q: Can I use Champion L76V's? The L76V's are listed for practically every Force engine except the 85hp, and I'm wondering what the difference is and what would happen if I used the L7's.<br /><br />Sorry for the long rambling message...but this is a series of problems that are likley all related.
