soundchaser
- Joined
- Dec 8, 2009
- 176
Re: sorry if Im asying this the wrong way show me how if I am
Geez, I just wrote some chit, Went to post it and wasn't logged in. That sucks
Anyway sorry I haven't been here, Been putting a boat together for myself.
This is a common problem with the new ethenol fuel. The guys here are correct In that you need to take the carbs apart, But Let me add a few things. First make sure you get a few cans of Brake clean and with the hose nozzle blow out all your orfices and clean everything but the gaskets with the brake clean. Make sure you clean the the high and low speed jets too. The high speed is as stated behind the drain plug and the low speed is directly above that behind a screw at the top of the carb. What the main problem probaly is, Is the main fuel valve is probably clogged from above with the fuel hose that's falling apart because of the ethenol, Not that the valve is stuck. You'll need to replace all your hoses with fuel injection hose.
