Spark Plugs 5.7 Mercuriser
mgnau1
Two problems.
1st. Is there a special plug wrench I need to properly R&R plugs. A standard wrench will work but hard to get o plug and when I do wants to break plug.
What type of plug?
Laddies
Banned
Re: Spark Plugs 5.7 Mercuriser
Same anwser here as when you posted in outboard, we need a model and serial number. Silvertip should stick to his own shortcomings on his abilities to anwser simple questions
I Guess I must have Missed Something..............
Anyways,.................
350 Chevies,.....Aka; your 5.7l Mercruiser have used the AC MR43T sparkplugs since Forever...........
The 1,+ Only Change came with the introduction of the Vortec Heads.........
The Vortecs take a Longer Reach plug,....... I believe the # for those is AC MR 43TS..........
So,....... If by chance your 5.7l Mercruiser is New Enough to have Vortec Heads,...... You'll need the Long plugs.......
If it's a 1995/6 or Older motor,...... You'll be needing the AC MR43T plugs........
Laddies
Banned
bondo and mgnav, heres a couple more listings from champion spark plugs....I count at least 3 for the chevy 350 or 5.7 liter. I dont ask for serial or model numbers to pad my post count like some others do ---Bob.
bruceb58
You use ESP? :)
bruceb58
Bondo,
Doesn't the Vortec enginge use the MR43LTS?
I think the MR43TS can be used in place of the MR43T in the older engines. The "S" means extended tip and the "L" means long reach.
You're Probably Right,.........
I'm using My Memory for reference,..... Not a Book......
