BAproject
- Joined
- Sep 2, 2009
- 276
I am in the process of tracking down the reason my 4.3 mercruiser (1991) is heating up to 180 degrees at idle running on "muffs" in my driveway.
I have replaced circ pump, risers, hoses, and t-stat. Have not changed the impeller but pulled the pump feed hose off while running and there was plenty of water supply (no air in it)...it was actually a shocking amount of water that was shooting out!
Here's the question (or 2 I guess). The water feed hose is cool, the 2 hoses that go to the risers are also cool, the exhaust hoses (the ones with check balls in them) are hot and here's the question, is the hose feeding to the circulating pump supposed to be hot to the touch? I read the manual and I noticed that some hot water feeds back into the engine, but it seems really hot?
Any other causes for the overheating or the circ pump hose heating up (other than impeller)?
Thanks in advance, I am racking my brain trying to figure it out.
-BAproject
-BAproject
