BAproject
Thread starter- Joined
- Sep 2, 2009
- 276
Cooling....Baffled....Anyone?
Just wasn't ready to let this post die yet...
I did some more investigation....and pulled both exhaust manifolds, inspect and flushed them, water flow is good. No rust in the exhaust chamber, minimal surface rust in cooling channels.
The rubber exhaust flappers are a bit loose but nor melted and could probably use a replacement.
Flushed water thru both sides of the heads to see if there were obstructions, and there were not, free and clear.
I am puzzled, how can the engine be overheating on 1 side still
Is there any other thing I am missing here? other than the possibility there is a block inside the block? water does trickle out of the drain hole in the bottom of the block.
I understand I have posted a lot to try and resolve this issue, to no avail....any last ditch advise is truly welcome!
