BAproject
Thread starter- Joined
- Sep 2, 2009
- 276
Re: Specific Cooling Question...HELP PLEASE
So i guess everyone is as puzzled as I am about this overheating issue
again;
New impeller
Hoses
140 t-stat
circ pump
risers w/ restrictor gaskets now
Belts
Still overheating gets up to 200 on gauge, but gauge seems to read 5-10 higher then IR temp gauge on temp sender.
A few more pieces to the puzzle that may help diagnose....
I bought an IR temp gauge and here are some of the readings
base of water intake manifold appx 170
circpump inlets and block 175 - 185
exhaust manifolds 210 right at mate to block (same temp on block right at exhaust manifold)
exhaust manifold down to 160-170 3 inches away from block
risers 140-150
more diagnostics done, I took the check balls out, stretched the springs and reset the nylon balls
pulled the feeder hose at the transom and fired it up....water shot straight out, no air, solid stream..this is def not the problem.
No obstructions in power steering cooler either...
Any thoughts would be super helpful!!!
-BAproject
does anyone know the next place to check
again;
New impeller
Hoses
140 t-stat
circ pump
Belts
risers 140-150
-BAproject
