Woodonglass
- Joined
- Dec 29, 2009
- 25,932
Re: Sport-craft restore
One thing for sure, she'll be a LOT more quiet!
check the link in my signature on how to cap your stringers. If you're getting air bubbles try using a bit less resin. Using to much has a tendency to Float the 1708 and cause air. Precoat the wood then put a bit of resin on your roller and start rolling from the bottom of the stringer to the top do NOT roll back down. Go back to the bottom and roll up again. Use a chip brush to dab not brush the cloth at the fillet point. This will help cut back on the air bubbles.
The fillet weren't to bad, just every place else. I guess I used to much resin. I'll figure out how bad it is tomorrow. I'll probably leave it, I had put on a layer of CSM before the stringer was placed in the boat.
So would it be easier to use several layers of 8oz cloth on top?
Bill,
I just stopped by to check out your progress. Thanks for your advise on my rebuild. Your new transom core looks very solid. That is one sweet little boat you've got there.
Bill, I know you want her to be strong but...Boats are like planes you want them to be Strong AND Light. I would think twice about adding to many additional bulkhead/Crossmembers and Pouring on additional resin. Resin rich mixes can actually weaken the mix and allow it to crack and let water to penetrate to the wood. If you use CSM and 2 layers of 1708 she'll be much stronger than the original factory layup and still be light too! Stick with the original design and make sure and do a good job with the glass work, keeping it free of air bubbles etc and you'll have a strong, light craft that will last for decades.
Sounds Good. Just wanted you to be aware!
