Re: Spyware??
"it says your computer is infected!
windows have ..........a spyware infection
it is recomended use special antispyware tools
to pervent data loss.windows will download and install
the most upto date anti spyware for you."
Don't download it!!! My dad responded to a similar message and was infected with the SpySherrif progam. It hijacks your PC, slows it down with clandestine activity and almost makes it unusable. It is almost impossible to remove because it is hidden deep inside windows and keeps re-installing itself. I finally had to format his PC and rebuild it. You can use this tool:
http://www.spychecker.com/program/hijackthis.html
to see if you are infected. It lists all the programs running and gives you a definition of whether it is a bad thing. Doesn't remove the problem, just identifies it. I find Microsofts Antispyware tool to be very effective.
Good luck.
Good luck.
