stainless rubrail
letsgo19
Has anyone installed stainless hollowback over rigid vinyle rubrail on a bayliner 2004 205?
seabob4
Re: stainless rubrail
Is the vinyl extrusion designed to accept the SS insert? If so, yeah, I've probably done it, oh, say a few thousand times...:cool:
letsgo19
Well what i wnt to do is install 1/2" hollowback stainless on top of original rigid vinyl rubrail but i think the original rail curves downward slightly toward transom using 3m 5200 and offsetting screws from original The issue i worry about is the curvature of original.Can you bend stainless hollowback?So no its not designed to accept it,is what i'm suggesting possible?
seabob4
Yes, SS insert is "bendable". As the shear starts to slope downward towards the transom, simply pull it down to meet the curvature, drill your hole, shoot your 5200 in, pull it back down run your screw, then continue on. When the curvature straightens out, pull it up and do the same thing.
It will go around corners too, as long as the radius isn't too tight. A heavy rubber mallet words good to "pound it a round". Just screw it in close to the corner so it doesn't "spring" on you. Piece of cake...:D
letsgo19
May i add you to buddy list in case i need any advice during my project Seabob?
