Re: Stainless vs. Aluminum
Lets clear a few things up...The Titan is stern lift overall lifter...The Titan HP 3 is a raked bow lifter....
3)The Titan is designed to handle high power applications.
[FONT=Arial, Helvetica, sans-serif]
Titan propeller is designed with a high camber blade section and large blade area to provide better load carrying and fuel efficiency for the high power marine engine. [/FONT]
The newly developed MF Titan series propeller is specially designed to match the Bravo Two driving system. With its excellent efficiency and performance makes the new MF Titan series the best choice for the sport fishing application.[/FONT]
4)The HR Titan 3 Series is specially designed for high speed planing hulls.[/FONT]
The High Rake Titan series is very suitable for high speed[/FONT]
[FONT=Arial, Helvetica, sans-serif]planing hulls. High rake blade design delivers outstanding acceleration and notable bow lift. Extra cupping ensures handling performance.[/FONT]
I am going on with the numbers you have provided...4800@42mph and a 21p 3blade alum gives you a 13% slip...probably reality and good numbers
Now going with a 20p ss hopefully you will gain in effeicny...about 3% which should net at 43 mph...given that the Solas is a bowlifter...
....decreaseing the wetted surface area....maybe 1-3 mph above and beyond 43....along with a midly better holeshot....(less pitch)
Make no mistake the stilletto is a great prop but not a 20p and do not believe that it can make up 1" of pitch the solas is no under performer i have both.
Now all the stuff is just opinion or thoughts...and the 20 should by the numbers work out better. But what no one knows is how they the props will react with your hull....im just bett'n on the numbers and the bow lift as i have experienced and solas states. My experience with the stilletto in a 3blade.. is a overall lifter and a great one at that...and the 4 blade is a fantastic stern lifter....maybe a bit to much for my old tub but it makes me happy...tons of midrange response..
I believe i-boats does have exchange program for Solas you may want to call them. In the end wether its a Hustler.....Stillettoo or Solas they are all great props and you will do well with all of them...
The reason for the drive ratio was to make slip calc on your current setup...if i were you id try and confirm your tach accuracy to within 100 rpm....that is how close were splitting hairs here and most older tachs are famous for being off by several hundred rpm..
