Sunny2007
Thread starter- Joined
- Oct 17, 2007
- 27
Hi everyone,
Pulled my boat out due to stalling and starting problems.
She's a 19' Bayliner Capri 5L ,holds an Penta Volvo AQ225E,4 barrel and i/o is a penta 275.
Starts good when cold,runs wide open,but stalls out at idle after warmed about half an hour later.Will start fine,start trolling and 10 minutes later stall again.
The high speed was affected also and before i pulled it out would only hit 3 g's WOT.
Since then have changed plugs.
Installed new ignition coil,cleaned connections on resister
Checked pickup tube check valve.
Fuel separater replaced.
Checked filter screen at carb line.
Always use stabalizer when winterized.
I've ordered a tuneup kit,points,condenser,& cap.
The rubbing block is badly worn and the shaft is now greased.
The gap was practically closed at the high point on the shaft.
The points look good but are very difficult to set now with the rubbing block the way it is.I tried to adjust at .017" ,she started but a little rough.Dwell showed 20,so i closed the points to .014 and it got worse.Can't seem to get the dwell up to 31.
I suppose i should wait till i get the new points tommorrow and give er another go.
Any suggestions would be appreciated.
