Starcraft Fishmaster 190 REDO
SPLMAXSAM
No Title
Day 9 - wow i removed alot of screws
SPLMAXSAM
No Title
Day 10 - i lay out all the pieces and measure them. I also indicate if they are covered by carpet or vinyl.
I also find more foam
SPLMAXSAM
No Title
Day 10 - new problem - some sort of rubber coating on the aluminum. Have much difficulty cleaning it off
SPLMAXSAM
No Title
Day 11 - try to manually remove rubber coating. I also have located an outboard and am going to go do an inspection
SPLMAXSAM
No Title
Day 11 - outboard visit. I came accross 1 owner low hour Mercury 2 stroke. The store , illness and racoon damage discouraged the owner from boating. The motor has been sitting for 15 years under cover
SPLMAXSAM
No Title
Day 12 - rubber removal still an issue. Tried wire brush, scraper and acetone. So far only industial stripper has an effect
SPLMAXSAM
No Title
Day 12 - more measurements. I strip off sunbaked carpet from the console. I will use as a template for new carpet
SPLMAXSAM
No Title
Day 13 - i ate
SPLMAXSAM
No Title
Day 13 - started really tginking about new trasom
SPLMAXSAM
No Title
Day 14 - took a break from hand tools and decided to try a power washer on the interior.
SPLMAXSAM
No Title
Day 14. I flooded the interior to check for loose and leaky rivots
TruckDrivingFool
Making good progress. That stringer damage makes another good case against pour in foam in my mind.
Is the rubberized coating the factory seam sealer? If so maybe it's better just cleaned up and left if not leaking.
Questions,
1. What's wrong with the Evinrude in the before pics?
2. I see the two ribs down the keel, do the ones seen in the bow run the full length also?
Teamster
Looks to me like someone came off some waves mighty hard at some time in the past,...
I'd say the foam added to the structural soundness that kept the boat from bending on impact,...
BWR1953
I think I read in one of the resto threads that Xylene worked to remove that rubbery stuff.
SPLMAXSAM
Sorry for mis spellings - doing post from my cell phone
SPLMAXSAM
No Title
Day 15 - start of bew stringers. As a wonderful surprise, my good fishing buddy dropped off some metal for me. Unbelivable!!!
I am going to cut out the bad metal and overlay the weak metal.
SPLMAXSAM
No Title
Day 15 - working on new stringers
SPLMAXSAM
No Title
Day 16 more stringer work. Cut out replace rivot
