Starcraft Fishmaster 190 REDO
SPLMAXSAM
No Title
Day 16 - more stringer repair
SPLMAXSAM
No Title
Day 17 - access rivots from outside , work on metal fab and see what UPS brought me
SPLMAXSAM
No Title
Day 17 deliveries!
SPLMAXSAM
No Title
Day 18 - more metal work
SPLMAXSAM
No Title
Day 18 - i traded my buddy Sheet donuts for use of rivot gun
SPLMAXSAM
No Title
Day 18 - Flipped the 19 footer
SPLMAXSAM
No Title
Day 18 - inspect hull to find much 3m 5200 applied to all rivots
SPLMAXSAM
No Title
Day 19 - work on new stringer through hull rivots. Seal hole that was caused by floor screw
SPLMAXSAM
No Title
UPS brought me some 2 part pourable foam (expands about 4 to 1
SPLMAXSAM
No Title
Day 20 - remove 3m 5200 from rivots using scraper and wire brush
SPLMAXSAM
No Title
Day 20 - working upside down and under the boat - pulled off sun baked worn and torn vinyl from the gunnels
I also listed every part on paper. I defined the part by make (wood or aluminum) , material ( carpet or vinyl) and size
SPLMAXSAM
No Title
Day 21 - testing out gluvit and acetone
SPLMAXSAM
No Title
Day 21 - testes some accent lighting i will use for night fishing. Also started sanding the hull
SPLMAXSAM
I bought the boat "bare". The PO had removed all electronics, fishing items, safety equipment.
fishin98
Looks like a heck of a project and you got a plan......As far as the trl.....now is the time to put the boat on the floor and take the trl to a sandblaster....I had mine done for $200, then I primed and painted. SOOO much better than wire brushing and sanding. What kind of kicker are you going to mount on the back, along with the 140 merc.
GA_Boater
So is she finished already?
You're 3 weeks into work after only 2 days.
Or you have a time machine.
SPLMAXSAM
Yes boat and trailer are 90 percent done
I had ideas no plan
SPLMAXSAM
No Title
Day 22 hull sanding. Trailer inspection and shoping. Sunbaked pin stripe is going to need majic eraser
SPLMAXSAM
No Title
Day 23.5. Got the majic eraset
SPLMAXSAM
No Title
Day24 - start to mock up new transom. I use carboard to help visualize what i will need to make the transom
