- Joined
- Oct 25, 2011
- 25,262
Re: Starcraft Jet Star 15 Restore
Pix of the bend/dent.....
Depending on where it is, the surrounding surfaces, access & severity of the damage, there is no 1 best way to treat all damage. Often the damage has 'stretched' the aluminum, and unless you can shrink it, it may be tough to remove. Also depending on how the damage occurred, the aluminum may have become 'work hardened'. If you were to attempt to re-form it, the aluminum may fatigue & crack.... Heating the aluminum to re-form it can also cause fatigue & failure.
But with out pix, that ^^^ is all just info to keep in mind...
Ok. Thank you! On the side (i think its called the gunwale, its where I cyrrently have rod holders), It is not a flat surface. It seems to have been bent. How can I make this lat again?
