boatbeginner1
- Joined
- Jun 17, 2012
- 311
Re: Starcraft Jet Star 15 Restore
I got a fiend helping me every other weekend so I'm gonna try!
There are small passageways for the water to drain in the center of the "ribs" that are clogged.How can I get the water to flow under the center like I think its supposed to?
While working on the rub rail under the bow, I looked at the dash wood. It looks like it is only held in by screws up both sides of the dash, then 2 sets of screws held up by wood, extending under the bow cap. In theory, I should be able to unscrew the screws, slide the board out, the replace it - Remember, in theory!
I'll clean the boat out this week, then Saturday, I'll try to finish getting the rub rail off. If anyone has a trick on getting rusted nuts and screws out, PLEASE TELL ME!!!![]()
I don't see any reason not to code you wire as you plan, just not sure how long the white tape will stay on. I'm sure there are a lot of older outboard around with non-stock color wiring!
Many have tried but I can't remember anyone being able to get it out without doing the cut or peel.
Thanks for confirming my weakening memory!!! :joyous::facepalm:
