sevanseriesta
- Joined
- Jul 12, 2012
- 303
So after looking at the motor, I saw that the starter has no wires hooked up to it. I have looked for wiring Diagrams for My specfic motor but the closest that I could find is a 1969 115 Johnson. This is a 1970 115hp Johnson model # is 115esl70d I am not sure what the "D" stands for but when you look it up on the document that is posted in the sticky it does not show a "d" on the end of the model #.
So to double check I need to attach the bottom post of the starter solenoid to the post the sticks out of the starter, and is there a certain gauge that I need to use? Also where do I Attach the ground wire on the starter. Bottom or top or it doesn't matter?
Next I see that there is something that was attached to the starter solenoid post but was cut is there anything that I should be looking for or should something be coming off of that? See second Pic
Also I need to run a Power Wire from the Battery to the Top post of the Starter solenoid? Right. Also does this wire need to be Fused?
