starter problems???
jtroxtell
ok so i have a 97 glastron w a 3.0 volvo penta 3.0 took it to the lake, anchored down and drank all day, forgot to turn pump on to drain water! when i got back to boat water was up to starter..drained water..tried to start..starter grinds and wont even try to turn over? any ideas? starter shot? need to dry out? i know this was was a stupid move on my part but yalls help is appreciated..thank you
jerryjerry05
Re: starter problems???
Batteries hot?Good connections? Pull the plugs and see if there is water in the pistons.Then start checking the starter.
Was it running good before it stopped.Hit anything? J
jtroxtell
was fine..didnt hit nothing, started it ran it about a hoursish to a spot we call the islands, anchored down..hung out about 5 hours without running pump..i was just assuming it was the starter though, it makes the grinding noise of a starter problem when you turn the key over. water was not high enough to get in motor or anything i dont think. it was just high enough where the starter was in water..for how long i dont know..stupid move on my behalf as i said earlier..so pull the spark plugs and look for water is what you say?
Don S
If the starter got water in it, it now needs repaired or replaced.
jtroxtell
don s..thank you for your response as ive read alot on here and see your mostly always correct lol.. am i correct though, that it is the starter since it has a high grinding noise when i try to start it? im sure it could have used a new starter anyway..will the starter dry out and be fine? or is it a def replace or repair issue? thank you
jtroxtell
ok that sucks but as i said my fault im learing as i go.. but does this sound like a starter problem to yall? since it was wet setting in water i just assumed but i am no expert. but i do know grinding noise is a starter problem so thats why i asked
Don S
How many times do you need it repeated. Get it fixed or replaced. That water causes rust, rust causes things to not work.
Take it off and take your starter to your local starter/alternator shop. Let them check it out. They can usually fix them (if repairable) cheaper than replacement.
jtroxtell
ok question again..would this cause the engine to not even turn over if the starter is gone? it dont act like it wants to turn over or nothing, it just grinds when u turn the key
fishinpa
troxell you may want to first see why you are taking on enough water to flood the bilge :eek:! lol
fish
