Starter Question
tev2229
I recently had some starting issues. I think these issues were caused by my starter pinion gear and the teeth of the flywheel on my 470.
I put in a new starter pinion, only to have it chewed up again. Here are my questions:
1. Should the starter pinion gear be fully extended (engaging flywheel) when the starter is not being powered? Other starters I have seen move forward when engaged, then come back away from the flywheel when turned off. I am thinking I need a new starter :eek:
2. The teeth of my flywheel are pretty beat up. I have chewed up two starter pinion gears. Is this replacement difficult? :redface:
Anyone face this problem?
zbnutcase
Re: Starter Question
The starter gear should be retracted when not powered, and the hardest part of ring gear replacement is removing the engine.
tev2229
Is there any case of marine starters having the pinion forward, unlike an automotive starter, to avoid sparks when starting?
