Starting a Long Sitting Rebuilt Motor
Hardcore
1977 OMC 140 chev 4 cyl. Was rebuilt about 5 years ago but has been sitting in the boat ever since with no oil. (not my boat). We are going to get this thing running but figure there are probably some steps to take to properly lube and prep the engine for running after sitting so long. what is the procedure? i have a few ideas but want to hear some others.
T-Max
Re: Starting a Long Sitting Rebuilt Motor
Wow. Why has it had no oil while sitting? Was it ever run after the rebuild?
That's for starters.
Fishermark
You would certainly need to pre-lube it. You can take the gear off the bottom of the distributor and then use your 1/2" drill to turn the distributor to lube up the engine. (I don't know if you could easily find the right tool for that engine).
Fishermark
Here's what I am talking about - you can even use a spark plug socket to turn the shaft - fits perfect. ;)
EMC 1810SS
If it has a flat tappet cam and hasnt been broken in yet, then it may be a good idea to pull the cam and re apply a good cam lub or at a minimum a moly lube to keep a lobe form going flat.
Hardcore
poor decision making is the reason
like i said, not my motor though
Adirondack
Go to Harbor Freight and get a chevy oil priming tool. They have them all day long. Pull the distributor, valve cover, and plugs. Prime the heck out of it untill you have oil coming out of every rocker. Put an ample amount of oil down each plug hole, and hand rotate the crank. (you may want to have an assistant run the priming drill while you turn it) When you think you have turned it enough turn it some more. Put your distributor back in. (properly timed of course) Now with the plugs out spin her over some with the starter for a bit. (could be messy so cover the plug holes with a rag or something) Put the plugs in and light her up. (don't forget your fresh water muffs) As long as it didn't sit with a lot of moisture in the cylinders you should be good to go.
EddiePetty
...just to add a touch to Adirondack's comments:
If you suspect an accumulation of condensation in the pan, first add a quart or so of light engine oil to the 'empty' pan, allow a few minutes to float any moisture and then drain via the pan plug if accessible or, using the drive socket down the distributor hole, pump it out through the oil filter housing (plastic bag over the oil filter housing).
After any moisture is removed, install a new filter and pressurize the system as above. Cycle oil long enough to remove any residual moisture, rust or free-floating crud.
After starting, be observant of any fluid leaks from dried gaskets. :)
Jim Marshall
Kroil makes a product that you can put down the cylinders if you suspect any problems. I had a boat that sat for ten years and I put it down the cylinders before tearing it down. The stuff worked great.
It is supposed to free up rings.
Jim
zbnutcase
Those tools only work on V8s and 90 deg V6's
Adirondack
Why is that ZB? I haven't tried it YET, but I have a 4 cyl apart right now, and it looks like the same oil pump shaft as the 6 and 8. Not that it's a big deal. I'll make what I need. Just curious.
Fishermark
zb is right - that why I said you would have difficulty finding the right tool - it is easier to make your own with your existing distributor.
