Starting a motor out of the boat.
flargin
Mercruiser 7.4 Bravo 1, 1989.
I want to start the motor out of the boat, to confirm I don't have any issues or leaks.
I read Don's Sticky on how to troubleshoot a starting system, and looking at the wiring diagram, I think the actions I have to do to start the engine, out of the motor (Thus without any of the controls - using the end of the connector only):
1. Emulate the ignition ON, by shorting Red/Purple(6) to purple (5)
2. moment switch the starter on, by shorting Red/Purple (6) to Yellow/Red(7)
with the colors and numbers from the diagram below:
Is there anything else I should need to do? any other info/diagrams already available?
Bravo Wiring diagram
Anchor Management 1
Re: Starting a motor out of the boat.
Just use a jumper wire from the + on the coil to power on the battery then jump the starter or a starter button.
CharlieB
Water supply?
You don't want to burn up the raw water pump running even a few seconds dry.
flargin
EDITED: So your skipping the wiring harness all together... good idea, beats the tracking down the circuit :) Thanks!
Water... You bet that one. Plan on running a hose into a temp line to the 'in' on the water pump.
Fuel will be similar, temp fuel line to the in on the filter (pre pump)
Thanks
