My force has problem with starting . It seems that I can not start it if it is in the water. Only when I trim it out and water leaks out from the leg it starts but also hard, never on first crank . I have to crank it with maximum throttle when not in gear ( this throttle is out of gear only cca 2000 rpm) . Then I trim it down to the water. After I trim down you need to wait for 5-10 seconds till water goes again through it and the bubbles start from exhaust . After that I can reduce the throttle and it works on idle but also dies sometimes because of weak idle. In idle it misses and spits fuel every few seconds on lower carb. If it dies I have to trim out again, wait till water leaks from the system and crank it again. Sometimes even 5-6 times. What could be the reason of hard starting? Timing is good, spark on all cylinders good, compression good.
