Re: Starting my 59' Starcraft flooring project!
I just want to make sure i'm understanding.... measeure down fron the top of the boat (gunwale from what i understand) to where i want my floor, mark that same measurement all the way around? Wouldn't that be saying that the gunwale is parallel with the water?
Also, i'm not using ONLY 50' of material. It's just what i've got the money for at this particular time and it will get me started. atleast do the frame around the edges and such and give me something to play around with untill next month. (bills hit pretty hard this month)
Thanks!
When working on a boat you throw your level away, you'll run yourself crazy and will be building and then tearing things out trying to use a level.
Boats are put together by measuring.
Mark where you want the top of the deck in one spot, then measure down from the top of the gunwale to that spot... then take that dimension and measure down from the gunwale all the way around the boat in about one foot spaces and that will be the top of your deck/floor.
If you try to take it to the lake with a level the hull is going to sit differently in the water everytime you move... it would make a great video to watch of somebody trying to do that though.:laugh::lol::laugh:
As for your deck framing plan, there's no way I can draw up a framing plan only using 50' of material... you'll probably need to stick to your own design for that.
Thanks!
