Re: Stator/Rectifier wiring question
If you have a simple 12v automotive probe style tester, you can test the output of the rectifier (red wire) for a steady bright light. If the light doesn't light then there is a problem. If the light does light and it's similar in brightness to when you connect the probe to a known good 12v battery source your rectifier is o.k. and the problem is from that point to your battery.
If the light doesn't light probe the yellow wires one at a a time and you should see a dim light that gets brighter with engine acceleration. Both yellow wires should do this. If that's happening then then rectifier should be replaced. If you have nothing from one or both yellows then either the wires have been cut or the charging coils in the stator are faulty.
OK, I did the test on the (RED) wire from the rectifier and it was a fairly good light. Not as bright as the battery put out, but not bad. I tested the three yellow wires from the stator and they all showed a dimmer light that brightened with a rev of the motor.
Next, I checked the volts in the battery and it was 12.48 prior to starting. I used a volt meter on the battery when started and with a rev, not a big one, the reading went from 12.48 to 12.55, and without the rev it settled back down again.
I did a continuity test on the red wire that goes from the connection at the rectifier wire to the the cable that connects to the battery and there's good continuity. I'm assuming that this is all correct. So.....is the little bit of voltage rise that I'm getting with the rev correct for my setup?
I appreciate your patience. This is kinda driving me nuts.
