travis46815
- Joined
- Jun 18, 2010
- 18
140 merc alpha 1 drive. My problem is... I switched props from a standard aluminum to a Turning Point Legacy aluminum, which has the same rake and cup as a stainless prop. during the madness, i realized i had a clearance issue with my trim tab, so i got the grinder out and fixed that, so i thought. now my problem is, that at wot i constantly have to hold my wheel or the boat will steer to the left. I have tried turning the tab both ways, and it doesnt make a difference. it is a bear to turn right. i had no problems before the prop change, and i have checked all of the cables for problems. it seems to be fine from low to mid range, but the trouble starts at higher rpms. can i take my trim tab off for a test run to see what happens, or will i hurt something? my boat does not have power steering. i was thinking maybe i took too much off of it? maybe i have to get an anode made for stainless props?
