Re: sticky piston rings on 1978 115 evinrude
Yes.. I Checked Comp On Top Left 75psi, Bottom Left 101psi, Top Right 30 Psi, Bottom Right 95 Psi. After Test I Tilted Motor Up And Poured About A 25 Oil 75 Diesel Mix In Cylinders To Try To Loosen Things Up . Rotated Engine Over Several Times And Checked Comp Again , Increased Very Little. Thinking About Pulling Te Head Off And Also Replacing The Jets , Mabye It Was A Combo Of Problems Like Water Pump And Running To Lean , I,m Not Shur Do Not Know This Fellow I Bought The Motor From
