Re: sticky piston rings on 1978 115 evinrude
thanks, got the 78 tore down cylinder walls are good , so ill just replace the pistons, rings, and all gaskets. the water pump and thermostates will get replased too.
The 78 gearcase wont fit on a 77 model as the linkage is totally different do to the 78 is a mechanical shift and the 77 is hydo-assisted...shift rod is different, shifting length is different,linkage on block is different...![]()
