Sticky rings??
bubbakat
Re: Sticky rings??
Hotrod I am proud for yea man. Job well done.<br />The sweet satafaction of sucesses.
Hotrods
Re: Sticky rings??
Yea, never thought i would get to install all the goodies I bought prior to rebuild.. Fixed fuel gage, installed nice indash compass. install cooler on bow, T-top will have to wait, takin her for her break in in the AM.. <br /><br />cleaned all the grease off her.. and if you look at her just right...you can see a big SMILE!!!<br /><br />OBJ please let me know if you can get that file. you need to download it, follow the directions that it say's.. dont left click to oen right click and save<br /><br /> I will not rest untill you do..<br /><br />Rod
OBJ
Re: Sticky rings??
LOL....OK Rod....will do. I just gotta download "QuickTime". I wanna see it go too!!! :D
alanR1
Re: Sticky rings??
Don't forget, you will have to set the idle for int the water. It will idle great on land but when it is in the water completely you will have to set the idle for that. Good luck!
Hotrods
Re: Sticky rings??
SPent the day breaking her in 25-1 mix<br /><br />hour 1 and 2 3000rpm max<br />hour 3 3800rpm max with WOT for 1 minute every 10 minutes,<br /><br />I am now in hour 4-10 3/4 throttle (4000rpm max) with WOT for 2 minutes every 10<br /><br />She did idle alittle low 500rpm but she ran like a clock WOT got me 5300 RPMS @ 35 KNots<br /><br />
<br /><br />
OBJ
Re: Sticky rings??
Rod.....ya' just make a bunch of wrench's proud. Great Job Buddy!!!! :D :D
fishhawk16
Re: Sticky rings??
This has been a great thread, I have watched from the sidelines since it began, very enjoyable. Good work Hotrod. And congrats, You've inspired me.<br /><br />I found this site about 2 months ago and am completly addicted to it.
Hotrods
Re: Sticky rings??
Originally posted by 24gradyexp:<br /> HotRod <br />Who did you have bore the block ?>
Windsor MAchine shop on rt 130 in Windsor a few mile outside hightstown.. Make sure you are dealing with a shop that does marine engines.<br />And if I could do it so can you... get your self a manual read it..read it again, then again.<br /><br />YUPPERS>. ..This was a very big deal to me.. and a great thread. is shows the power of this site. <br />Last night I couldn't sleep a wink, just thinking about hitting that throttle and wondering what was going to happen. I just can't stop thanking all of you for the work and concern you guys offered.
D
DJ
Guest
Re: Sticky rings??
YIPPEEEEE! :) :) :) :D <br /><br />I've been watching too. I stayed out, you were getting advice from the "best of the best".<br /><br />Once she's broken in, you may want to consider re-propping her to run 5500+.
Hotrods
Re: Sticky rings??
Yea I was wondering where you were DJ, Figured as you said.. I got 5000 with trim all the way down. if it trimmed up 25% it took me right near 5500. but wasn't sure if i had her up too high?
D
DJ
Guest
Re: Sticky rings??
Good deal hotrod. Like I said, you were in good hands.<br /><br />Nice topic!
24gradyexp
Re: Sticky rings??
Thanks for the info, I have been reading the manual and this winter I might give it a try. Just needed a local machine shop. Hightstown is not that far away from me. I have a 92 225 with one scored wall and 85 psi on the rest of the cylinders. It goes through gas like it was free and the boat is running 10+ mph less than it should @ 5500 (only about 34 mph according to GPS)<br />Just want to make it through the season as it does start right up and run very well despite the issues.
flech01
Re: Sticky rings??
Hey hotrod can you take a picture of the head now to see how nice it looks with all the wires taped up and everything in order?
conchecko
Re: Sticky rings??
Wow, better daze ahead HotRod! I was just reading this thread from start to end, very interesting, but yet scarey. This by far is best Thread i have read over!! <br />I see G Dane is on board, you are in good company!<br />-------------------------------------------------<br />Goodluck!<br />Conchecko
reeldutch
Re: Sticky rings??
hi hotrod i got the pictures on this site<br /> http://groups.msn.com/outboardpictures <br />i had it running for a few minutes and it shore sounded sweet.<br />my starter needs to be replaced or repaired.<br />can you explain how you set your timing propper because i would like to try it myself.<br /><br />reeldutch
Hotrods
Re: Sticky rings??
Nice... looks just like mine.. I didn't set my timing. If you didn't move any linkage adjustments everything should be just as it was. if you need to time it read your link and synch in the manual 20 times..lol....to post a pic right here..you goto the pic hit properties, copy the URL then past it in the box here where it sez..image..
reeldutch
Re: Sticky rings??
darn i tried to save my starter motor i just putted new brushes in but it still doesnt work right.<br />monday i'l get a new one shoot the starter.<br />grgr<br />reeldutch
reeldutch
Re: Sticky rings??
i got a used good starter for 70 dollars and it starts a lot better.<br />before i puttet the powerhead on i did the tstats of course.<br />but i am a stupid a.. because i was to cheap to buy new ones and i thougt with a good cleaning and checking them in hot water if they would open i would be fine.<br />Bad bad bad mistake. the tstats do not open at all and the motor was running hot.i shut it down immidialtly and let it cool hoping the tstats would pop open.<br />nothing happend so after a second attempt and running hot i took the tstat out and replaced the housing and the motor run cool.<br />defenetly runs like crab if you dont have tstats in them.<br />so i trew the old stats out and tomorow i wil; install new ones.<br />i'm now a firm believer in trowing things out and put new stuff in while you can.<br />i had the ph off , replacing tstats was a joke but now....rrrrrr<br />how cheap can i be well real Dutch<br /><br />reeldutch
