still having problems
mitts
150 vro evinrude put new gas ,plugs,gas lines ,cleaned cARBS ,still no top end power till i push choke in can someone please help me:
HighTrim
Re: still having problems
What year outboard?
Did you thoroughally clean the high speed jet and rebuild the carb or just spray carb cleaner into it? Does pumping the primer bulb pick her up? Have you tried a separate fuel tank?
mitts
yes i cleaned jets i took off carbs ball is hard it is a 1988 vro evinrude do you think oil has somthing to do with it
