sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
Hey guys, Im beginning to think this motor is possessed!!!!!
Anyways, E130txoar 1995 V4 Looper 130hp
Timing bounces back and forth while the engine is in Quickstart. (Motor backfires and is hard to start. Runs GREAT once quickstart has disengaged) Disconnect yellow/red wire and ground out white/black wire and quickstart STILL tries to engage (which is not supposed to happen). Once the white/black wire is grounded out from the pack, it goes out of quickstart after the first 5 seconds and runs fine. The ONLY way the engine will not enter quickstart is if I disconnect the 4 pin amphenol connector from the timer base to the powerpack. I swapped out the timer base with a known good timer base and still have the same issue.
When cranking the motor over to do the Joe Reeves WOT timing procedure, the motor advances to its quickstart timing, whether yellow/red wire is connected or not. Again, if I disconnect the 4 pin connector from the timer base, timing goes back to normal.
Sent powerpack to CDI for warranty, they checked it and said it was NOT faulty. I argued that I really felt it was, and they sent me a brand new powerpack.
I STILL HAVE THE SAME ISSUE!!!!!
I do not have voltage coming in from the yellow/red wire unless the key is being turned. There is no voltage coming in from the kill circuit.
My only guess at this point is that maybe I have a short and voltage being fed in from the ground??
This motor also has the original black ignition coil wires instead of the new grey ones. Could this be a culprit?
Thanks guys, I am really pulling my hair out here................
