Stringer repair
I would fire up the die grinder with a few roll-loc discs and feather it, then sand and buff
mickyryan
looks like some one hit something, that would cause it to crack inside and out, grind down on inside and repair there , imho then on outside grind the crack and fill and re gel cote you could grind the outside with a dremel so its not a huge repair if you did all of the structural repair inside.
bjf66
the crack on outside is not really adjacent the crack on FLOOR up front
The chine of boat in front looks clean no marks
so grinding moreeeee
I think Ive done my apprenticeship in grinding so with this project
anyway chin up, nearly out of the hull
thanks for comments
mickyryan
wonder if there is wood in that chine, seems there is something weeping discolored, closer examination will tell you the story for sure:)
bjf66
I wonder whether the boat previous was left outside and filled under floor with water from rain, I took some pictures before cutting floor and you can see the water mark
Previously up front there was a ballast tank, which I cut out, so water could of being hanging around in the hull for sometime as boat may have been sitting on flat without cover
bjf66
attached are starboard and port (this is where gel coat is cracked) under floor pic
and have a photo of ballast tank removed and filling void with foam
bjf66
well been traveling for last 2 weeks so not boat repairs
Yesterday spent most of the day on back tucked up in bow grinding, lovely job!!!!
Turns out the floor is all Coosa board, and looks like there was some separation of the tabbing on to side, and this looks like what I was seeing
Then previous owner had put some PB over the joint which had more filler than resin as very chaulking when grinding it out
So kept digging with dremel and grinder, decided to take a wider area down to the floor and inner hull glass
So ground out area approx. 800x700mm, will lay some cloth this morning
1 layer 600 CSM
1 layer 937 grm multi axis
1 layer 600CSM
1 layer 937 grm Multi axis
then can tidy up the bow and finish the flocote
bjf66
Fuel tanks
Picked up 2 side alum fuel tanks last week, approx. 100 litre capacity each, so interesting to see whether can fit these into boat
bjf66
finished just clean up and flocote tomorrow
bjf66
Need to modify back of boat as presently wash is likely to come over transom as originally boat was setup for outboard
So was thinking as engine sits forward of the transom as have gearbox and dropbox mounted between engine and transom, then need to cover in the rear
was thinking of using current deck lines, and then would construct engine hatch to cover engine
If this was closed in then would help to protect the trim tabs pumps, Arneson trim pump and bunch of other stuff
What material would one use to close of the back of the boat, was thinking along the lines of using the Coosa 1/2" board (or marine ply) reinforced, with ribbing/structure to support, as may want to walk across the back of the board and need plenty of strength
assuming would just fabricate the structure, as opposed to making mould to build a outer skin
Then laying the usual 2* layers 2 oz CSM, 17 oz Multi axial fabric, then would need to gelcoat
anyone can throw us some pointers would be good
here are some pictures of what was thinking current and filled
your strength is in the fiberglass, so I would probably use 1/4" or thinner to make the shape.
bjf66
Scott
would you fabricate this up as you went or make a mould and try and laminate the skin with gelcoat?
I have some coosa board left but not in one piece,
The total area Im looking to cover is 700mm x 1150mm
Im not to sure whether the coosa board would flex if made in 2*350x1150mm even if I strengthen underside with ribbing?
What do you think make in one piece or 2 piece?
I would fab in place with 1/4" or thinner to get the shape and build up from there.
bjf66
had a close look the rest of the cap/deck area around back of boat seems to be 12mm thick
so have purchased 6mm Gurit H80 board and will use as core and laminated 600 CSM and 937 gram Biaxial to each side to build up the required thickness of total laminate
bjf66
picked up 2 * 100 litres fuel tanks which I hoping will fit towards stern, baffled and 4mm, need to have the floats and siphon pipe installed
bjf66
started on rear deck fill in
used hardwood 40x20mm, bolted 5/16: unc stainless steel, and glued 2 battens into rear cut out
used 3 side braces 40x20mm and rebated these into the side battens
Then epoxied the braces together
used 6mm Gurit board (43"x24")
bottom side: used 1*2oz CSM, and 1*25oz biaxial
2oz CSM
another 6mm Gurit board (43"x24")
Will build up 2 layers of
2oz CSM, and 25oz Biaxial
That should come close to +1mm below rear deck surface
Need to go away for few days for business, will give the epoxy time to set, and try and finish over Easter period
bjf66
enjoying the long weekend to get back into the boat, and day light saving changed up at 5.20am into the boat
while I'm constructing the rear deck,have been thinking about its time to drill the bungs holes in transom
what size bung hole is fit for 22' boat????
Hopefully after the rebuild I don't plan on taking too much water on board, but one never knows
The guy at the boat chandler indicated plastic was better than stainless steel as know galling when installing the bung
bjf66
laminated the front section of the rear deck with Gurit board 6mm*3 and then incorporated a step in the lamination to glue on to front of the support board
managed to laminate the rear deck with approx. 15 degree angle to suit the top profile of original deck
used 2*6mm Gurit glued together with 600 CSM (2oz) in between
had a sit test on the board seemed sturdy enough
drilled the 2 rear drain hole for the bungs
used 25mm hole saw, and then 29mm dia drill
will glue in 25mm stainless tube along with bung
Good day working
should be in position to glue/screw the rear deck down tomorrow
