Stringer repair
bjf66
drilled hole 29mm drilled in transom
bjf66
finished off lamination of the new rear deck insert
VE on the wood to seal
drilled 20* 3/8x2.5" long stainless steel recessed head and nylock nuts to spread load
made up glue mix with VE resin and West #403, and #413 high strength fillers for gluing
coming together now
bjf66
bjf66
cleaned up the rear deck inset this morning, fillet, more grinding, cut out the 43"x39" cloth, and will lay 4 coats of fibreglass on top of inset
Laid this afternoon
#1: 2oz CSM, and
#2: 25oz biaxial cloth
Tomorrow will lay
#3: 2oz
#4: 17oz biaxial
bjf66
cleaned up with a little sanding, laid more glass
#3 2oz
#4 17oz biaxial
should clean up okay
bjf66
Jumped up onto top of the newly constructed rear deck insert and gave it the old 100kg jump up and own on it see whether it cracks, looks like passed with flying colours
Then gave the rear deck insert a skim of VE/PB to fill the coursiness of the 25oz biaxial, then sanded and filled again on parts low parts
sanded transom
sanded the floor
placed a skim of flocote over the floor to fill some of the coursiness of the 25oz cloth, sanded off
was running short on the grey flocote and had decided the grey was a little dark, so mixed the flat grey/satin white together 50/50 which helped decrease viscosity without thinning and used 100mm roller to put down final coat
colouring looks better plus its a got a little sheen to it not too much
75% of floor finished, remaining 25% to be done tomorrow morning, so I can get out of the boat after completing, seems a few more days then no more sanding inside boat for a while
2* rear dungs installed in transom
bjf66
finished the application of last flocote tonight, colour certainly looks improvement on the dove grey
engine rails get bolted back into the stringers on weekend,
set up reinforced plate on stringers to be welded
engine can then be aligned into final resting place
bjf66
mocking back up the stringer rails
10mm alum plate, needs welding
Need to weld and re-drill 4 of the 8*12mm top as when I cut stringers down and glassed top /side of stringer must of placed a little more glass on there, so holes need to be relocated
will be away for few days, and will set up engine mounts starting next weekend
bjf66
put back in the Z-drive,
Need to make up new 10mm thick mid-plate for the drive as the existing plate has few extra holes in from past use
getting ready to organise someone to weld the 10mm stringer engine rails
Have day off tomorrow, dropping engine back in to set up for final time
exciting
bjf66
Scott
Yes new type, clean burning no emissions, perfect foot print when not running
Trying to do my best for the enviroment prior to turning on the 9.1 litre Chevy
mickyryan
good god i wouldn't wanna pay for that fuel lol and here i am worried about having enough fuel with a 60 gallon tank and a 3.0 litre lol
bjf66
fabricating engine mounts,
made up a 20mm thick disc of timber and placed into front cam bearing, drilled hole to take laser pointer to centralise the engine in centre of hull
worked good easy to see at night
continue to fab rear engine/transmission mounts
bjf66
started cutting a few holes in dash for gauges
decided to use Gaffrig white as had a few here need to purchase few more, 2* 3 3/8" and 4*2" Dia should see us right
bjf66
arranged for local welder to weld up the 10mm alum plate for the engine and middle mounting plate
should be all finished on friday morning, good step in right direction
pulled out the char lynn helm to see what modifications I need to do to make it work
- needs a 20 degree wedge behind the dash, made this up, laminated into place
- filled the original steering column hole
- started thinking about seats and layout
picked up some bolster seats a while ago not sure whether will use them, looks like I need to have them mounted approx. 100-150mm off the floor
bjf66
anyone have any recommendations on low height seat pedestals with good shock absorber
The Char Lynn helm is being installed at 20 degrees, so should have 125-150mm underneath the seat
The side mounting bolt hole for seat is 320mm x 140mm (12.6x5.5")
