Stringer repair
bjf66
need to wrap the CSM/Biaxle over the side caps to seal the gurit board, and then rough sand
bjf66
merry Christmas everyone
boxing day here in Melbourne, chilling out after the big meal yesterday
time to get into boat
started ripping out motor, transmission and Z-drive
had to push boat back out garage , with motor coming over bow, plenty of dust to clean up
bjf66
Like a jigsaw puzzle when you start stripping the guts out of the boat
At some point it’s all got go back together
bjf66
Cleaned up the Daytona crash gearbox today
Seems to nice to paint again
I wonder how the clear coating would stand up to the harshness of marine salt, humidity and moisture or whether should just paint it the aluminium epoxy colour ?
bjf66
I checked out Matrix by PPG which was recommended to me, however there clear is 40% solids
I'm in Australia and have used in past engine enamel from KBS coatings DiamondFinish - Clear Coat - Application Instructions - Automotive Clear Coat (kbs-coatings.com)
The guys behind this company were involved with POR so I'm informed but the KBS range of coatings is next generation which has 60% solids and you can flow it on with brush and looks like oven cooked 2 pack, however works on bases of humidity and is one shot (no mixing 2 parts)
2-3 coats should be enough
KBS made in USA and Australia
cant be that bad?
Happy New year all you boaters
hopefully its better than the POR15 products.
bjf66
Stripped back the mercruiser Bellhousing to reveal the raw casting
What a shocker
Realise now why they apply decent coat of black paint, as casting was rough finish
I suppose rough the Brett we to hold the paint
sanded it up ....knocked into shape
Looks half decent now
bjf66
Cleaned everything out of boat
Dragged her outside gave good hosing down to get rid of dust
sealed the exhaust, surface drive, trim cut out and holes with fibreglass resin and then flocote
next few days finished fibreglassing cap /decks
What a shocker
its rough as a cob because its cheaper to make that way.
bjf66
scott, we supply into metal casting industry, and I would be a shame to send that casting out the door to some lucky customer
bjf66
raining today in melbourne, difficult to use the orbital sander outside
dragged the hatch inside and started sanding, filling, more sanding the hatch, need to fill it over and prep the underside then its good for 2 pack epoxy undercoat
bjf66
Been thinking about location of trim pumps, as the 280 K-planes purchased showed up last week, freight form USA taking forever at present due to covid, shipping schedules.
The best location would be bolt them to inside rear transom, close to the actuators, however would be difficult to get in there is any future problems
Few weeks ago travelled to antique race boat meet, and when moving around the pits noticed a lot of the boats had windows cut out of rear deck, with access panels there, generally made from tinted lexon, so you can get access to the inside transom, as well as see what's going on from outside the boat.
Thought this seemed a good idea
Thinking I could router a step in the window cut out and then drop the lexon panel into the recess to make a smoother look
Not sure how else you could do this without relocating the trim pumps forward and running longer hoses between pumps and actuator fittings
bjf66
Applied epoxy undercoat to underneath of hatch yesterday
Use roller and brush as weather wasn’t that good for spraying
Just to see how glass filled and get hang on putting down some paint
needs a little more fill, that epoxy paint is sure thick
bjf66
Yesterday made up piece of gurus boat to finish off the contour of gunwale so it follows the profile of the hatch
came up okay
bjf66
Was up early and outside this morning at 06am ready to start fibreglassing
However had a reasonable dew on boat so had to towel the old girl off then hit it with sone acetone
Took a little longer to put down the laminate. As working the cloth into ridges was longer than expected
Used 600 grm CSM/612 grm biaxle cloth
It’s been 25 c all day to had time to harden up nicely
Was thinking need another layer over that section of boat as it will be high traffic area
So will lay 200 grm CSM/612 grm biaxle over gunwale tomorrow morning
That will give the gunwale approx. 40oz when finished
it’s been 25c today so glass has had chance to harden up
bjf66
4pm start sanding back the laminate
had dinner
back out there this evening after heat died off
manage to get 2nd laminate down of 225 grm CSM/612 grm biaxle
will sand off tomorrow
maybe able to get a skim coat of the outsides tomorrow
good progress today
bjf66
26c today a little warm for fibreglassing outside
Sanded the laminate on the gunwale
Came up good
So all set for some filleting/ skim coat to blend profile in
decided to extend the passenger seat pedestal
This way when skiing and I turn the seat around 180 degrees facing backwards I can have the seat back not quite touching the dash which gives passenger more leg room
fine tuning the seating arrangements
